Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
pdf already exists; it cannot be added
2 REPLIES 2
jose_oltra
453 Views, 2 Replies
jose_oltra
I'm just writing this post as there are many post out there with the same issue and I won't publish in all of them.
Issue :
When publishing a PDF through Job processor , randomly you get "pdf already exists; it cannot be added". You don't find any pattern for the failure. It's not the category, it's not the file type. Yesterday it worked, today it doesn't....
The problem is on the Vault database. Your existing PDF file has been classified  as "0" when it should have been classified as "7" , which corresponds to Design Representation
Inventor
Revit
Vault Professional
Autocad
Issue :
Inventor
Revit
Vault Professional
Autocad
2 REPLIES 2
jose_oltra
in reply to: jose_oltra
jose_oltra
So, the solution is Autodesk solving this bug, but in the meantime , there is a workaround.
IMPORTANT : This workaround implies modifying a value on the database. So, DON'T do it.
Go to SQL management Studio, access your DB.
Find the files with the correspondent TipFileBaseName.
From all the FileMasterID find the one that represent your PDF. Look the FileClassification Value. It should be 7.
Once changed , resend the Job on the queue. It publish the file normally.
As you may have noticed, I'm not given any further detail on the steps on purpose. If you don't know how to find the data, you should not try this workaround.
Thank you!
Inventor
Revit
Vault Professional
Autocad
Thank you!
Inventor
Revit
Vault Professional
Autocad
johan.degreef
johan.degreef
Is this solved in 2025?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
