we are using the "replace"-function in Vault, because we have to replace older states of standard parts to newer ones.
Usually the "replace"-function is working well. But often by choosing the part which will replace the old ones at this point Vault crashes/freezes.
After confirming the new standard part with "ok" Vault chrashes/freezes and we have to kill the process.
We tried this at different workstations and always we had the same problem.
Do someone know this problem or had a similar problem and is there a reason and/or solution?
Vault version:
Regards
Norman
You should update your server and client to 2017.2.4 Update to see if the crash still happens.
we did the update at all clients and our vault server. The problem is still the same.
