Numbering Scheme - 000.000.000 up to 999.999.999
js10000
js10000
How is it possible to define a numbering scheme that allows us to use sequential numbering up to 999.999.999 while using "." every 3 digits for better readability?
We also want to add .XX for Work in Progress and .01 - .99 for revisions
So for example 123.456.789.XX
We cannot get this to work because the auto-generated sequence does not seem to have an option to "interrupt" the numbering every 3 digits.
Thank you very much!
Best regards
johan.degreef
No experience, but can't you create 4 seperate fields?
000.111.222.333.44
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
js10000
Yes, but only one field can increment by itself. The other fields would have to be entered manually.
Gabriel_Watson
For more intricate solutions you will probably need to set a custom numbering scheme in SQL at the ADMS (see post below and research further into how numbers could be broken down with periods or how multiple fields could act as a single number):
https://resources.imaginit.com/manufacturing-solutions-blog/using-a-common-numbering-scheme-for-file...
