Tried multiple times to Install Autodesk Vault Professional Server 2016, but the installation fails.
ADMS 2016 installation is trying to uninstall ADMS 2014 but fails to do it and get the following message.
FAILED: Autodesk Vault Professional 2016 (SERVER) - An error occurred while installing this product. For more information view installation log file.
Below are the log file error message.
2017/9/17:23:02:21 PK834DADM01 WWW-TRIRIGA-01 Installing Uninstall compatible Data Management Server: "E:\Autodesk2016\en-us\edmprechecks\edmwrapper_x64.exe" /uninstall_updgrade_codes {B50D0205-E1F5-4F27-A889-05E3E7BE12D1};{62A9BE06-3422-4DDF-B86B-70727DE53DF6};{4F63AA49-D014-4401-BA5D-E7426BEB433F};{B0EF03F8-B7EA-4929-977D-009C4FB18ECD};{E14B6310-1764-0103-0100-03993952EDAC};{E14B6310-1732-0103-0100-03993952EDAC};{E14B6310-1764-0102-0100-03993952EDAC};{E14B6310-1732-0102-0100-03993952EDAC};{E14B6310-1732-0101-0100-03993952EDAC};{E14B6310-1764-0101-0100-03993952EDAC};{E14B6310-1764-0100-0100-03993952EDAC};{E14B6310-1732-0100-0100-03993952EDAC};{E14B6310-1864-0103-0100-03993952EDAC};{E14B6310-1832-0103-0100-03993952EDAC};{E14B6310-1864-0101-0100-03993952EDAC};{E14B6310-1832-0101-0100-03993952EDAC};{E14B6310-1832-0100-0100-03993952EDAC};{E14B6310-1864-0100-0100-03993952EDAC};{E14B6310-AAFE-0100-0100-03993952EDAC};{E14B6310-AAFE-0101-0100-03993952EDAC};{E14B6310-AAFE-0103-0100-03993952EDAC}
2017/9/17:23:02:23 PK834DADM01 WWW-TRIRIGA-01 Install Uninstall compatible Data Management Server Failed Installation aborted, Result=1603
2017/9/17:23:02:26 PK834DADM01 WWW-TRIRIGA-01 Rollback Microsoft WSE 3.0 Runtime Succeeded
2017/9/17:23:02:27 PK834DADM01 WWW-TRIRIGA-01 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/9/17:23:02:27 PK834DADM01 WWW-TRIRIGA-01 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619"
Anyone's help will be appreciated. PFA grab for the reference.
