Mapping Aggrivation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
***post in total frustration***
OK, so yeah, it's been a while (about 7 yrs) since I've had to create and map properties to autofill a title block.
So here I am going through the Help topics Adesk offers as a guide to refresh my old man's memory. But here I am, fighting with the app again because, as I've seen too many times, Adesk's documentation on the process is well...lacking, or outright incorrect.
(Hint Autodesk: Consider farming such out to actual users. We are available and willing to offer)
For example: I'm attempting (and failing) to map the "Latest Approver" from our vault lifecycle to the appropriate field on the drawing. So I go through the steps and get to the mapping menu, select the Entity of "File", but if I do so, the "Provider" field doesn't list Vault, it only lists "Inventor" or "Inventor DWG". Obviously this is due to "File" being selected, correct? The only other option for Entity type is "Item". We don't use Items.
So I select "Inventor" for the Provider, that then offers me to select the Property. That field and it's popup menu is blank. If I select "Import From Vault", it takes me to the Vault menu to navigate to a file....WHAT FILE???! It needs to be mapped to the Lifecycle!!!
What am I missing?
This should NOT be this darn (don't dare spell it with an "m" instead of a "r", it'll cost you 10 years worth of dedication to Adesk.....but I digress) hard.
At this point, I'm going back to the old school way and making it a prompted entry, the very thing we are trying to avoid.
Now for the betting line.....what are the chances I'll find the info I'm looking for soon after I post this?
