I need the option to manage Outlook mails in Vault: I would like to import them via Drag & Drop directly, I need the numbering from Vault , I must be able to map the mails's subject etc into Vault properties and I need to manage Outlook attachements as attached files in Vault.
Solved by RajSchmidt. Go to Solution.
Vault Professional has an Outlook integration for managing and storing emails.
Hi Irvin,
I checked the possibilities I have once again. You are right, I can do a lot with the standard interface.
So all that remains on my wish list is that I can insert messages by Drag & Drop directly from Outlook. And of course, I would like the number generator to fire…
Regards
