Job Processor running update wrong value description properties
aji.sugiyantoro
aji.sugiyantoro
Hi Everyone !!
We have an issue that Job Processor running apply wrong value properties of version after the file released. it show up randomly from thousand file in Vault. we have try to change map properties "description" from bi-direction (file to vault) to one-direction (file to vault). it reduce the issue, but the issue still randomly show up.
We compare description properties vs another properties with same map properties. and just in description properties Job Processor update wrong value.
We have update patch in every client and server on the same build, but this issue still show up.
Could you suggestion to us how to solve it ? We hope it never show up in the future.
ihayesjr
Can you show the "Description" property mappings?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
CGBenner
@aji.sugiyantoro
Do you still need some help with this issue?
Chris Benner
aji.sugiyantoro
Hi @CGBenner and @ihayesjr
thank you very much for the feedback on our issue,
our issue has been answered by Support Team Autodesk on
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2022/EN...
But, we still curious about it.
On existing workflow, we create 3D Model on project explorer and assign/update item , than  process the life cycle until Released on project explorer environment.
As i know, the synchronization within the 3D model and Item Master just can be done by manual “Assign/Update item”.
Do you have any suggestion, when the 3D model vs Item Master are not the same value, the client can’t change the state to the next state.
Is there any action like state transition that we can check the list to replace manual handling (Assign/Update item) ?
CC : @amin.nurdin
