Item master child creation issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I‘m having trouble with item creation and item BOMs in Vault.
I’m using a custom Level of Detail on some iLogic assemblies, and for these assemblies only, no items are being created for their child files when I 'Assign/Update Item...'
It shouldn't make a difference to the issue I'm having, but for extra info, the configure Assign Item settings in Vault are set to 'All ' under the sub-heading 'Rows that will be turned ON during Assign Item'
Their is a mixture of parts/assemblies within these iLogic assemblies with Normal/Purchased BOM structure. Some already have pre-exisiting items and some require new items to be created. But after assign the assembly to an item, no child items are showing under the Item master BOM, its not even picking up the pre-existing items. I've double checked the Inventor BOM and that's looks normal.
Strangely enough, I found that changing the Structured BOM properties to ‘All Levels’ on all the affected assemblies solved the problem. However, I’ve not had this issue with other assemblies that use an custom LOD, whose Structured BOM properties were set to ‘First Level’
Any thoughts on what could be the cause?
