Is is possible to create another SQL instance on the same SQL server which been used for Autodesk Vault?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently, utilizing Autodesk Vault to manage AutoCAD Plant 3D project files for department 1.
For that we've already created an instance in SQL server and working on with Vault perfectly.
Now we are planning to create another SQL instance for department 2 on the same SQL server which we've been used it for the department 1.
Is this the right way of approach?
Below is agenda what we are trying to achieve:
1. Single SQL server
2. Two SQL instances (department 1 and department 2)
3. Two Vaults in ADMS (department 1 and department 2)
Is there any complication on this?
and if we performed this, can we simply enter the details of Vault name as well as SQL server instance name while creating plant projects based upon department 1 and department 2 users? (please refer attached images for this)
Please kindly check and provide your feedback.
Thank you.
