- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The report of the BOM in Productstream Professional 2010 shows incorrect quantities. (see attachments). On a German forum someone mentioned that there is a hotfix for this issue, unfortunately he did not mention which one. I can not find a hotfix on the support side that applies to this problem. Please help
Regards, Martin
Edit: I think I partially solved the problem. I applied ts14051617 on the server and the standard report that came with PSP now shows correct values. My report which I copied from the original still shows incorrect values. Is there a way to solve this without rewriting the report?
Martin van den Berg
NKM Noell Special Cranes GmbH
Inventor Professional 2019.3 + Vault Professional 2019.1.1
Martin van den Berg
