How to Search a file that most recently checked in?
BeKirra
Advisor Advisor
BeKirra
I do not find this function with "Find" in Vault.
Did I miss something?
Your helps are much appreciated.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Like you want the file that was most recently checked in?
I would just search for "Checked In in the last day" and then sort by the Checked In property.
BeKirra
Thanks for your help, but "Checked In in the last day" is not available in the search option in Vault.
X² + Y² = C²
The property is "checked in" and the option in the find dialog is "last day" the r something to that effect.
It is there. I use it frequently.
BeKirra
Yes, thanks a lot. Now I found.
X² + Y² = C²
