Database "EntityOwner" "Stamp" Replication Conflict
I set up a new replication environment with Vault Professional 2015 german
Everything seems to work fine. But when I do the first checks (add a new file, Get ownership of a previously existing file, Check it out / Modify it / Check it in) I run into a problem.
Upload to subscriber works, but upload to publisher failed.
So I look at the Replication Monitor (Management Studio) and I found following error message:
Fehlermeldungen:
'Microsoft SQL Server-Konfliktlöser 'Zusatz'' konnte den Konflikt nicht lösen.
(Quelle: MSSQL_REPL, Fehlernummer: MSSQL_REPL-2147023782)
english translation
'Microsoft SQL Server Additive Conflict Resolver' failed to resolve the conflict
When this error occours, it is impossible to copy the files
How to solve this problem?
Why I always get the "EntityOwner" "Stamp" Conflict
I do a crosscheck with an Vault Professional Training Vault 2014 english (from an Autodesk Training) and I saw the same error message.
But with Vault 2014 the files are uploaded to the Publisher
What is the difference between 2014 and 2015
or what I#m doing wrong?
Matthias
paul.gunn
Conflicts are expected here and should normally be resolved automatically (this is unchanged from 2014). I have never seen a case such as you describe (where for some reason the conflict resolver is failing).
It sounds like your best be is to log a support case on this as it isn't clear what the cause of this might be.
Paul
