How to move existing single users designs to vault
troyostrander
Message 1 of 8
troyostrander
New to Inventor coming from Fusion. I installed just Vault Basic. Looking for best practices or a tutorial for moving designs to the vault. Thanks.
Replies (7)
Message 2 of 8
SharkDesign
You are best asking in the vault forum, they are the Vault experts.
If they're only small assemblies though, you could just move them all to the vault directory, put all top level assemblies in one empty assembly and then check that in and the children will follow.
https://forums.autodesk.com/t5/vault-forum/bd-p/vault-forum-en
  Inventor Certified Professional
Message 3 of 8
dave.cutting
You could use the task scheduler to add multiple folders and files to Vault in one go.
Dave Cutting
Message 4 of 8
blandb
Create a vault project file with the same locations as the single-user. Then when you open the files with the vaulted project, you should be able to check them in. Keep in mind that the working folder, Content center and .ipj fall at the same level. IE (C:\Whatever you want to call this folder\ CC folder, Designs Folder - where all your designs are place, call this what you want, IPJ here). We also throw our design data in here as well so it can be tracked via vault.
Autodesk Certified Professional
Message 5 of 8
arkad_s
Autodesk Support
Autodesk Support
I will leave also few links that might be helpful:
Getting started with Vault | Autodesk
Vault Help | Setup Vault with Inventor | Autodesk
Vault Help | Getting Started with Vault | Autodesk
How to upload multiple Autodesk Inventor, AutoCAD, or other non-Autodesk CAD files to Autodesk Vault...
What are the best practices to upload huge amount of existing data into Vault? - Autodesk Community
If you plan to move all your design files into Vault you might also consider getting touch with Autodesk Partners/Resellers who can help you with this project - Partner Finder | Autodesk Support
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
Message 6 of 8
johannes.bauer
Autodesk Support
Autodesk Support
Message 7 of 8
lauri_barnhart
Greetings, @troyostrander!
Thank you for posting your question. Wanted to check in and see if any of the replies by SharkDesign, dave.cutting, blandb or arkad_s helped resolve the question you posted. If one or more of the replies helped, please consider clicking on the 'Accept Solution' button as this will help others with the same or similar issue find a solution quicker. If you still need assistance, please comment here so others in the community can jump in and provide additional information.
Lauri | Community Manager
Message 8 of 8
troyostrander
