- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day everyone,
I've recently found that when trying to move folders in our Vault server (from a current folder to something like an archive folder) that I'm unable to move them due to a vault restriction.
This restriction mentioned is that files can't be moved if they are checked out. This makes sense, but the file in question, not only isn't checked out, it does not exist. The file would always have the extension of: example.idw.dwf.
I suspect that while saving .idw files, inventor makes .dwf files temporarily, and that when/if Inventor crashes while files are being saved or checked in, this file remains. I've done a search for file extentions of dwf, and searched my PC for the file, but it's nowhere to be found. I've searched for all checked out files within this folder, and still it comes back clear with noting checked out. I can't force move or force check things back in, so I'm pretty stuck.
Any thoughts?
Vault Client Version: 2022.4.1
Vault Server version: 2022.4.1
Inventor Version: 2022.4.1
(basically up to date for all of 2022)
Nathan Kirton
If what I said helped you out, please use the ACCEPT AS SOLUTION or KUDOS buttons.
"I don't know why it doesn't work. It fit in the model!"
