File in Inventor Vault tree but not in Inventor assy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the 10+ years of using Inventor + Vault I have struck this problem twice. I did not get a resolution to the first instance.
I have an assy file that shows a file in the Inventor Vault tree that is not in the Inventor assy. This file is in Vault and is also shown (where used) in the assy. But the file IS NOT IN THE INVENTOR ASSY! It can't be seen in the model tree or the BOM on the Model Data, Structured or parts Only tabs. It cannot be found by searching in the Inventor model tree search function.
This file was in the Inventor assy at a previous version and was deleted. Somehow there is still a link in Vault that says the file is still being used.
Curiously if I run a Pack-N-Go in Inventor the part is shown in the Files Found list.
If I RMB on the file in Inventor Vault tree and select Find In Window there is no result.
I have deleted the non-used file and opened the assy and dealt with the Resolve issue but can't then check the file back into Vault as there is nothing to resolve.
I have opened the assy file, placed the spurious file, checked it into vault, seen that the file is indeed used in the assy. Then opened the assy, checked it out, deleted the spurious file and checked the assy back into Vault. I can still see that the file is in the assy but it's not!
To any Autodesk database gurus out there, I can supply the Pack-N-Go of the assy if required. In the previous company where I had this exact same problem I even supplied the database for Autodesk to investigate but sadly the issue was never resolved.
@Anonymous
PDMC 2021
Inventor Build 353 Release 2021.3.3
Vault Pro 2021 Build 26.2.24.0, 2021.2.1 Update
