Forums
Architecture, Engineering & Construction Community Hub
Back
Architecture, Engineering & Construction Hub
See all
Product Design & Manufacturing Community Hub
Back
Product Design & Manufacturing Hub
See all
Media & Entertainment Community Hub
Back
Media & Entertainment Hub
See all
Community Hub
Back
Community Hub
See all
Subscription, Installation & Licensing
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Forums
See all
See all
See all
Community Hub
Community Hub
See all
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Home
Vault Forums
Vault Forum
All community
This section
This board
Knowledge base
Users
Products
Turn on suggestions
Show
only
Search instead for
Vault Forum
Welcome to the Autodesk Vault Forum. Ask questions, share your knowledge, and make connections.
Let there be anything
Share what you’re making with Autodesk in the Community Gallery and let there be anything.
Share here
Activity feed
Communities by language
Ask a question, share your knowledge, or submit a product idea.
Start a topic
Options
Mark all as New
Mark all as Read
Float this item to the top
Subscribe
Bookmark
Subscribe to RSS Feed
Sort by Topic Start Date
All
Trending
Accepted solutions
Unanswered
Most Viewed
Latest
Oldest
New to the Vault Forum?
Start Here
Community managers
CGBenner
Vault Forums ideas
Share ideas for improving Autodesk products with the team that makes it and submit requests for the features that you would like to see.
Explore ideas
Related tags
"Assistant" "Fusion"
(1)
"Content center"
(1)
"custom attributes"
(1)
"Error"
(1)
"fusion"
(1)
"IDW"
(1)
"Inventor Professional 2024"
(1)
"Plotting"
(1)
"Properties"
(1)
"Revisions"
(1)
"Revit"
(1)
"Vault Professional 2024"
(5)
"vault professional"
(2)
"Vault"
(7)
"view panel "
(1)
"Workspace Sync"
(3)
.csv
(1)
.pdf
(1)
.step
(1)
.stp
(1)
2021
(1)
2022
(1)
2022 Thin Client
(1)
2023.3 Update
(1)
2024
(1)
2025
(1)
2026
(2)
2026 delete
(1)
2026.1
(1)
2026.2
(1)
3rd Party
(3)
@trasked
(1)
@vault pro 2025
(1)
@Vault Professional 2024
(4)
A3
(1)
ACADE
(1)
ACC
(1)
Account
(1)
add files
(1)
Add-in
(17)
Adding Files
(1)
addons
(1)
Admin General Settings
(1)
Administration
(61)
Administrators!
(1)
adms
(3)
after copy design
(1)
Aftermarket Vault Utilities
(1)
All sheets from the data source 'XXX' have been excluded dialog - Plot manager
(1)
AMD
(1)
API
(6)
ApplicationPreferences crash
(1)
archive
(1)
As released
(1)
Assemblies
(3)
Assembly
(1)
Assign Item
(1)
Associated files
(1)
(1)
AU
(1)
authenticated
(1)
auto
(1)
autocad
(4)
Autocad 2020
(1)
autocad 2021
(1)
AutoCAD 2024
(1)
Autocad Check In
(1)
AutoCAD Electrical
(3)
AutoCad Mechanical
(4)
AutoCAD MEP
(1)
Autocad Plant 3D
(2)
autocheck in
(1)
Autodesk Cloud PLM
(1)
Autodesk Inventor
(1)
Autodesk Inventor 2022
(1)
Autodesk Inventor 2023
(1)
Autodesk Inventor 2024
(1)
Autodesk Vault
(16)
Autodesk Vault 2025
(3)
Autodesk Vault Basic
(1)
Autodesk Vault Basic 2024
(1)
Autodesk Vault Server
(2)
Autodesk Vault Thin Client 2023
(2)
AutodeskVault2026.1
(1)
AutoDownload
(1)
Autoloader
(6)
Automaticly
(1)
AutoNumber
(1)
avfs
(1)
B360
(1)
Backup
(5)
Backup and Restore
(1)
Basic Vault Server configuration
(1)
batch
(1)
batch of number block in vault
(1)
Batch plot
(2)
batch print
(1)
Beta
(1)
Bigger assemblies or parts causes Inventor-Vault addin to freeze at check-in
(1)
Bill of Materials
(1)
Bills of Material
(1)
BIM 360 Document Management
(1)
BOM
(5)
BOM part and assembly.
(1)
BOM Structure
(1)
BOMs
(1)
bug
(5)
Bug Reporting
(1)
Bug Reports
(1)
Bugs
(3)
Buildings
(1)
bulk_migration
(1)
but still unable to check-in
(1)
C Drive
(1)
Cable and Harness
(1)
CAL
(1)
CD
(1)
Change Management
(1)
Change Order
(3)
Change Orders
(10)
Change State
(4)
check in
(5)
check in to vault
(1)
check out
(1)
check-in
(2)
Check-in Error
(2)
Check-out
(1)
checked out file
(1)
Checkin
(2)
child
(1)
children
(1)
Classification
(1)
Client
(114)
collaborate
(1)
command line
(1)
Comments
(1)
Company Moving to Common IPJ
(1)
Compliance
(2)
Config
(1)
Configuration
(2)
Connector
(1)
consistency checking
(1)
Content Center
(10)
Content Center Parts
(1)
contents centre
(2)
Copy
(1)
copy design
(22)
Copy Design component multiple referring drawings
(1)
Copy Design Problem
(2)
corrupt
(1)
corruption
(1)
Costing
(1)
crash
(4)
crashing
(1)
Create dxf
(1)
Creation
(1)
creation date
(1)
criteri
(1)
CSV import
(1)
Custom iProperty
(1)
Custom Library
(1)
Custom Objects
(2)
Customize Window
(1)
dark theme
(1)
Data corruption
(1)
Data Import & Export
(1)
Data Management
(2)
Data Migration
(1)
data standard
(4)
Data Standard 2022
(2)
Data Standards
(1)
datastandard
(1)
date
(1)
DB
(2)
delete
(1)
delete pdf
(1)
delete properties
(1)
Dell
(1)
Demote
(1)
Demote (+ DataStandard (DS)) causes filename to have lower case starting letter except upper case
(1)
Derived Parts
(1)
Description
(1)
Design
(1)
Design Copy
(1)
Design Review
(1)
DesignData
(1)
development cycles
(1)
Dialog
(1)
Dialogue
(1)
difficult to read
(1)
Distributed views
(1)
document
(1)
Document Browser
(1)
document type
(1)
Documentation
(29)
domain user
(1)
downgrade
(1)
downgrade vault
(1)
Download
(3)
Drag&Drop
(1)
DRAWING ERROR
(1)
drawing extension
(1)
Drawing Revision Block
(1)
Drawings
(6)
Duplicate part search
(1)
dwf
(9)
DWF Creation
(1)
dwf errors
(1)
dwg
(1)
ECNs
(1)
eco
(2)
ECO Routing
(1)
edit
(2)
Education
(1)
Electrical
(1)
email
(1)
Email Notifications
(1)
EMEA
(2)
enable File Purge
(1)
enable users
(1)
Engineering
(2)
ENGINEERING CHANGE ORDER
(2)
enum
(1)
Equivalence value
(1)
erp
(2)
Error
(8)
Error - Find Duplicates Display
(1)
Error 1024
(1)
Error and issues
(1)
error109
(1)
errors
(3)
Errors message
(1)
Event
(1)
Event Viewer
(1)
Export
(3)
Export documents
(1)
export reports
(1)
F360
(1)
facility management
(1)
Factory Assets
(1)
Factory member
(1)
Failed to acquire license. Please try again later or restart the product
(1)
file
(2)
File Associations
(1)
File Item Association
(1)
File Management
(1)
File search
(1)
filename
(1)
Files does not check in
(1)
filestore
(2)
Find
(3)
find and replace fine names
(1)
Find filter Number of Attachments does not work properly
(1)
folder
(1)
Folder Structure
(1)
Forge
(2)
Frame Generator
(1)
Free
(1)
freeze
(1)
full window not shown
(1)
Fusion
(2)
Fusion 360
(2)
Fusion Lifecycle
(2)
get
(2)
Global event
(1)
Greyed out menu
(1)
Groups
(1)
hardware
(1)
Has Drawing
(2)
Hatching
(1)
Help
(1)
Help & Learning
(1)
How to lock phantom assemblies
(1)
iAssembly
(2)
identify
(1)
Identifying Suppressed Files
(1)
idw
(1)
IDW.check in.error
(1)
impersonation user
(1)
Import
(1)
Incident ID: 35348
(1)
Including Phatom and Reference components in ITEMs
(1)
indexing
(1)
insert into CAD
(1)
Install
(2)
Install Error
(2)
Installation
(10)
Installation - Getting Started
(1)
installation and setup
(1)
Installation Errors
(1)
Installing
(1)
Integration
(1)
INTEL
(1)
INV2020
(1)
Inventor
(31)
Inventor 2019
(1)
Inventor 2020
(2)
Inventor 2021
(2)
Inventor 2022
(3)
Inventor 2022 upgrade
(1)
Inventor 2023
(2)
Inventor 2025
(1)
Inventor 2025.1
(1)
Inventor 2025.2.1
(1)
Inventor Addin
(1)
Inventor and Vault Professional Windows 11
(2)
Inventor Drawings
(1)
Inventor Modeling
(1)
Inventor parameters
(1)
(3)
Inventor Professional 2021
(1)
inventor read only
(1)
Inventor Vault
(1)
Inventor Vault upgrade
(2)
inventor vault version
(1)
inventor2024 vault2024
(1)
Inventor;Vault
(1)
iPart
(3)
iParts
(1)
iparts and vault
(1)
iProperties
(5)
iproperty
(2)
iproperty mapping
(1)
ipt
(1)
Issues
(1)
item
(4)
Item BOM
(1)
Item details
(2)
Item Master
(4)
Item Master in Vault
(1)
Item Release Process
(1)
Item update
(2)
Items
(33)
Items & BOMs
(4)
Items and Files
(1)
Job Processor
(27)
job processor custom jobs
(1)
Job Processor Error
(1)
Job Processor PDF
(1)
job server
(1)
Job-Prozessor
(1)
jobprocessor
(1)
jobprocessor Desktop Connector Autodesk Construction Cloud
(1)
jobs
(1)
last checked in version
(1)
Latest Approver
(1)
latest version
(1)
Library
(1)
library parts flagged as outside of active project workspace
(1)
Library upload
(1)
Licence
(1)
licencing
(1)
License
(1)
licensing
(1)
Life cycle
(1)
Lifecycle
(8)
lifecycle changes
(1)
Lifecycle Definitions
(1)
lifecycle state
(1)
Lifecycles
(28)
list
(1)
Live BOM
(1)
locally
(1)
lock instance
(1)
lock up
(1)
locking
(1)
Login
(1)
LOGIN ERROR
(1)
Login ID type
(1)
Login Issues
(1)
Maintenance
(1)
manage plot
(1)
mapping
(3)
Mapping Properties
(1)
mark-ups
(1)
Markup
(1)
markups
(2)
mass
(2)
master
(1)
menu
(1)
Menus
(1)
metadata
(3)
microsoft word
(1)
Migrating files
(1)
migration
(1)
Missing Feature
(1)
Mobile
(2)
Mobile App
(1)
Model states
(6)
model version
(1)
month
(1)
move folder
(1)
multi-site
(1)
NAMER
(1)
Navisworks 2019
(1)
new
(1)
New Standard file
(1)
New Upchain Webinar
(2)
No local files with unsaved edits
(1)
not compatible
(1)
Number
(2)
Number Generator
(1)
Number of attachments property for files
(1)
Number reservation
(1)
Number Scheme
(1)
numbering
(2)
numbering scheme
(2)
Numbering Schemes
(1)
Object Contents
(1)
Obsolete
(2)
offline
(1)
old copy design
(1)
OldVersions
(1)
OneDrive
(1)
Operating system
(1)
opt out scenario
(1)
oracle
(1)
out of date item
(1)
Pack and Go
(1)
page setup
(1)
parents
(1)
part family
(1)
Parts
(3)
Password
(2)
Pc
(1)
PDF
(12)
PDF ACM
(1)
PDF Creation
(1)
pdf export
(1)
PDF export issue
(1)
pdf publishing
(1)
PDM
(4)
Performance
(2)
Permission
(1)
Permissions
(3)
Persmission
(1)
pipe
(1)
Plant 3d 2020
(1)
Plant3D
(1)
PLM
(5)
plot
(4)
Plot Manager
(1)
plot styles
(1)
position Number
(1)
Prefix
(1)
Presentations
(1)
Preview
(2)
Preview Description
(1)
preview only
(1)
print
(1)
printing
(1)
Printing issues
(1)
Product Lifecycle Management
(2)
productivity
(1)
Project
(1)
project sync
(1)
Properties
(10)
property assignment
(1)
Property Compliance
(1)
property edit
(2)
Property Management
(1)
Publish
(2)
pull numbers
(1)
purge
(2)
Purge Unused
(1)
Question
(1)
Queue
(1)
quick change
(1)
reference designator
(1)
references
(1)
Release Bias
(1)
release file
(1)
released
(3)
released files
(1)
Remote work
(1)
RENAME
(5)
rename error
(1)
Rename Files
(1)
rename item
(1)
Rename Wizard
(1)
Renaming by Vault 2024
(1)
renumbering
(1)
Replace component
(1)
Replace ipt in iam
(1)
Replication
(8)
report
(1)
report thumbnails
(1)
Reports
(1)
Restore Backup
(1)
restricting download
(1)
restrictions
(1)
reuse
(1)
Review and Approve
(1)
Revision
(5)
revision block
(1)
Revision Control
(1)
Revision Table
(3)
revision vault
(2)
revision visibility
(1)
Revit
(2)
Revit Collaborate
(1)
Right Click button
(1)
roles
(1)
routing lists
(1)
sa
(2)
safe
(1)
save
(4)
Save As
(1)
save location
(1)
scaled to fit
(1)
Scanning related files dialog freezes after clicking OK on check-in dialog (Inventor Vault Add-In)
(1)
Schedule
(1)
Scheme
(2)
SDK
(1)
Search
(4)
search path mapping
(1)
Search Results
(1)
Searching...
(1)
Security
(3)
sendtimeout
(1)
sequential
(1)
serial numbers
(1)
Server
(15)
server install
(1)
Service Pack
(1)
Set Copy Design property values as custom value or with suffix
(1)
Settings
(1)
Setup
(1)
Setup and deployment
(1)
Sharable info
(1)
share design representation
(1)
Shared View
(1)
Shared views
(2)
simplify
(1)
skeleton modeling
(1)
slow
(1)
Software Upgrade
(1)
Solid Works
(1)
SolidWorks
(1)
SolidWorks add-in
(2)
Solution
(1)
Some items in original selection set are no longer available in Vault. ...
(1)
specifications
(1)
Speed
(1)
SQL
(14)
SQL 2019
(2)
sql server
(1)
Sql Server 2019 Standard
(1)
SSL
(2)
ssl letsencrypt
(1)
state
(2)
state change
(1)
state protection
(1)
States
(2)
status unknown
(1)
style library
(1)
Subscriber
(1)
Suffix
(1)
sync
(1)
sync to fusion
(1)
Synchronisierung
(1)
synchronize
(2)
system requirements
(1)
Tables
(1)
task scheduler
(1)
TC BOM item OffRows
(1)
Temp
(1)
Template sync
(1)
Templates
(1)
Thin Client
(38)
thumbnail
(1)
Tips & Tricks
(1)
title
(1)
Title Block Update
(1)
Titleblock
(1)
TLS
(2)
Training
(1)
Transaction
(1)
transition
(2)
Transmittal
(1)
troubleshooting
(3)
Tube
(1)
Tube and pipe
(1)
UDP
(2)
UDP PDF
(1)
UI hanging after some while of inactivity
(1)
UI issues
(1)
Unable to open Vault
(1)
Uninstall
(1)
Unique parts
(1)
unknown error
(1)
Unlisted
(1)
unresolved
(1)
Upchain
(1)
update
(4)
Update 2024.4
(1)
Update 2025.2.1
(1)
update view
(1)
Updates
(2)
updating
(1)
Upload
(1)
url
(1)
User Interface
(1)
User management
(1)
User-defined prop.
(1)
Vacuum
(1)
vaul email notiicaftion problem
(1)
Vault
(215)
Vault 2019
(3)
Vault 2021
(2)
Vault 2022
(16)
Vault 2022 plot manager
(1)
Vault 2023
(4)
Vault 2023 thick client instaled release
(1)
Vault 2024
(2)
vault 2025
(4)
Vault 2026
(3)
Vault add-in
(2)
Vault Add-On
(1)
Vault add-on not working
(1)
Vault and Nasuni
(1)
Vault and Task Scheduler
(2)
VAULT ARTICLE UPDATE ISSUE WITH DRAWING
(1)
Vault Artikel Revision
(1)
Vault automation
(2)
Vault Back up 2021
(1)
Vault Basic
(5)
vault basic 2019
(1)
vault basic 2020
(1)
VAULT BASIC 2021
(5)
Vault Basic 2022
(4)
vault basic 2022 copy design issue
(1)
Vault Basic 2023
(5)
Vault Basic 2025
(4)
Vault Basic 2026
(1)
Vault basic 2027
(1)
vault bom
(1)
Vault Categories Name Historical
(1)
Vault Check In
(2)
Vault Check Out
(2)
Vault Client
(5)
Vault Connector
(2)
Vault Copy Design
(2)
Vault Customization
(3)
Vault data standard
(1)
Vault Data Standards
(1)
Vault Duplicates Dashboard Re-Index
(1)
Vault ECO
(1)
vault error
(2)
Vault Explorer
(1)
Vault features
(1)
Vault file deletion
(1)
Vault file management
(2)
Vault Get
(1)
Vault Insert into CAD function
(1)
Vault Install
(1)
Vault installation
(1)
vault iproperties export import
(1)
Vault issue
(1)
Vault Issues
(3)
Vault Items
(1)
Vault Items Latest Released Revision
(1)
Vault Job Processor
(6)
Vault License
(1)
Vault Lifecycles
(1)
Vault Lifecycles and Drawings
(1)
Vault Migration
(3)
Vault Mobile App
(3)
Vault Numbering Scheme
(1)
Vault office
(1)
Vault Pack and Go
(1)
vault pdf
(1)
Vault PLM
(5)
Vault PLM Webinar
(1)
vault preview
(1)
Vault preview issue
(1)
vault pro
(2)
vault pro 2019
(1)
VAULT PRO 2020
(14)
Vault Pro 2022
(1)
Vault Pro 2023
(1)
Vault Pro 2025
(1)
Vault Pro 2027
(1)
Vault Pro Thumbnails
(1)
Vault problems
(1)
Vault Prof. 2025
(1)
Vault Professional
(26)
Vault Professional 2021
(8)
Vault Professional 2022
(7)
Vault Professional 2022 Item
(2)
VAULT Professional 2023
(8)
(3)
vault professional 2025
(1)
Vault Professional Client
(2)
Vault Professional PDF Publishing
(2)
Vault Proffesional
(3)
vault property change
(1)
Vault Rename Files
(1)
vault report
(1)
Vault Search
(3)
vault server
(3)
Vault Server Memory
(1)
Vault SQL Licensing
(1)
Vault status
(1)
Vault status icons
(1)
Vault Synchronisatzion
(3)
Vault Synchronization
(1)
Vault Thin Client
(9)
Vault UI - "More" button bug
(1)
Vault Visualziation
(2)
Vault Webinar
(3)
Vault Workgroup
(4)
Vault Workgroup 2019
(1)
vault workgroup 2020
(2)
Vault Workgroup 2022
(1)
Vault Workgroup 2023
(1)
vault2021
(1)
Vautl client
(1)
VDS
(2)
Versions
(1)
View
(1)
View in Window
(2)
Viewer
(1)
virtual environment
(1)
visualisation
(1)
Visualisierung
(1)
Visualization
(7)
visualization files
(1)
VP 2025 Installation
(1)
VP 2026 Installation
(1)
vpn
(1)
W. Authentication
(1)
warning
(2)
Webinar
(6)
Why some locked files have to be saved before checking in their upper assembly
(1)
window
(1)
windows
(1)
windows explorer
(1)
Windows Logon
(1)
word files
(1)
Workflows
(2)
Workgroup
(1)
Workspace
(1)
Workspace management
(2)
X-attach workflow
(1)
Xeon
(1)
xref
(1)
zoomed
(1)
Previous
Next
Top contributors
User
Count
ihayesjr
2
iamerm
1
johannes.bauer
1
View All
