- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys,
Wondering if anyone can help me. One of our hdd`s in the company crashed and IT had to install new one and changed the \\path for the DWF folder/storage.
So what we did is we updated designs.ipj to reflect the new folder. At the same time we started getting errors when we check in files. There is an option , we can create dwf file while checking the files in or we can send it to a job server. Either or doesnt work. If we create dwf`s while checking in it gives us the following message:
If we send it to the job server - server gives an error :
We also checked the machine that runs Job Processor.exe. Exited out and restarted it again, same result.
For some reason the Settings menu is grayed out. We logged in as an Admin. See below:
I`m wondering if there is an option in Settings above where you can change the publish folder or not?
Is there anything else I can check/change?
Any help is appreciated.
p.s.: no other problems, just problems with publishing DWF`s.
Alex.
