Duplicate search error
johan.degreef
Advisor Advisor
Message 1 of 8
johan.degreef
Our jobprocessors loglevel is already set to 1, and this is the log.
Parts are not indexed. Does anybody have an idea what might be wrong?
Many Thx
vGeneral 19/06/2024 9:09:25
Job  318011 : Autodesk.Vault.DuplicateSearchExtractor
General 19/06/2024 9:09:26
Job 318011 | Autodesk.Vault.DuplicateSearchExtractor | The following files were not indexed:
$/Content Center Files/en-US/PTN_SS304_PIPE/PIPE_200214_45.ipt
Indexing: PIPE_200214_45.ipt | Failure
Completed executing
Job  318012 : Autodesk.Vault.DuplicateSearchExtractor
General 19/06/2024 9:09:27
Job 318012 | Autodesk.Vault.DuplicateSearchExtractor | The following files were not indexed:
$/Content Center Files/en-US/PTN_SS304_SQUARE_TUBE_PROFILE/PROF_150002_1893 SS304 (1.4301).ipt
Indexing: PROF_150002_1893 SS304 (1.4301).ipt | Failure
Completed executing
Job  318013 : Autodesk.Vault.DuplicateSearchExtractor
General 19/06/2024 9:09:28
Job 318013 | Autodesk.Vault.DuplicateSearchExtractor | The following files were not indexed:
$/Content Center Files/en-US/PTN_SS304_SQUARE_TUBE_PROFILE/PROF_150002_1800 SS304 (1.4301).ipt
Indexing: PROF_150002_1800 SS304 (1.4301).ipt | Failure
Completed executing
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (7)
Message 2 of 8
johannes.bauer
Autodesk Support
Autodesk Support
@johan.degreef  did you review this article and checked if the parts have physical properties?https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Duplicate-search-j...
HTH
-Johannes
Customer Technical Success
Message 3 of 8
johan.degreef
@johannes.bauer
I opened a part that failed to index and see this.
Message 4 of 8
johannes.bauer
Autodesk Support
Autodesk Support
The Jobprocessor user has permissions to download the part, right?
I would open up a support ticket so someone can test this part in his environment to doublecheck. Also you can share the server logs then to see if there is something suspicious.
HTH
-Johannes
Message 5 of 8
johannes.bauer
Autodesk Support
Autodesk Support
One thing you could check is to enable the job retry and set it to 2 to see if a subsequent job would fix the issue:
HTH
-Johannes
Message 6 of 8
johan.degreef
Could it be something on Windows security level?
If I logon with the same Vault account on my laptop as on the dedicated machine, it works. On the dedicated machine it does not.
Message 7 of 8
johannes.bauer
Autodesk Support
Autodesk Support
@johan.degreef
one would need to see maybe a process monitor trace to see what it does when it fails
HTH
-Johannes
Message 8 of 8
johan.degreef
@johannes.bauer
These are parts that fail. Maybe you can test them on your side?
Could it be that it is template related? On my machine this works well, with same jobadmin account.
