Can anyone explain the difference between these 2 settings in the Control Tab for behaviors in Vault?
This is a "Released" state
This is an "Obsolete" state
For some reason obsolete files in my Vault are set to This is a "Released" state. I wanted to know if this is, or could be, causing issues with obsolete files in the Vault. I have not seen any errors or problems but it just seems odd that it would be set this way. I did not configure these behaviors. I inherited Vault administration duties and no one here can answer why this was setup this way.
What would be the ramifications of changing this now? Does it even need to be changed?
Thank you.
Thank you.
Solved by gandhey. Go to Solution.
Can you please explain what do you mean by obsolete files in my Vault are set to This is a "Released" state. How do you make this out ? Are you using out of the box lifecycle process OR a custom LC process? And just to highlight the lifecycle state name can be any string and underneath in the setting it could be set to 'This is Released' or 'This is Obsolete' state.
To answer the difference in the states : the intention of these 2 states itself is different. For eg. 'Obsolete' state files could be the orphaned files which user no more use in any of their active projects. 'Released' state in most cases indicates that the design is frozen and no more change in design files is expected and the design can be released to manufacturing.
Please note different users may use these 2 states with different interpretation too as per their needs.
To answer "What would be the ramifications of changing this now? Does it even need to be changed?" - sorry but i think this cannot be answered without knowing how it is being used. Please note usually companies have security for access controls for files / objects in vault, based on different lifecycle states of the LC process. for eg. 'Released' state files are locked, different users/groups could only access (readonly/modify) 'Released' files and not any other files.
So in short you need to know how/why are the lifecyles states used in your company. That will help answer your question - if you change the administration from 'Obsolete' to 'Released' state, what impact it will have.
regards,
Yogeshwar
(Vault team)
regards,
Yogeshwar
(Vault team)
Obsolete files (at least in my opinion) are files that you want to control who can see them and they are normally not used anymore. I have used this state to keep from deleting files from Vault, because once deleted the files are gone forever. Normally I set the settings to allow only Admins to see files that are marked as obsolete.
Released is for files that are still in production and can still be seen by everyone with permission. These files can also be revised or walked through whatever life cycle you have set up.
Does that make sense?
Basically if the files cannot be produced anymore then they are obsolete for audit trail purposes. Released is used for files currently still being used.
I understand the fundamental differences between the 2 states, what I am having trouble with is the interface selections that are highlighted in the screenshot I posted in my OP. Permissions are set so that obsolete files are not visible to most users. I was just curious as to what those 2 interface options really "do" inside of Vault and if having the selected entry (This is a "Release state") set for "obsolete" files is causing any problems that might be going unnoticed. I apologize if my question is not clear enough. I'm not sure how else to ask.
Tom
Tom
Sorry. Posting my reply using my appropriate user ID
I am not sure if I got your question completely, but to answer " what those 2 interface options really "do" inside of Vault " :
And as indicated earlier, the string name may be anything it is the underlying 'This is Released' OR 'This is Obsolete' that is considered in above LC transition actions.
Hope this is something you are looking for.
Yogeshwar
(Vault team)
Yogeshwar
(Vault team)
Does the "This is an 'Obsolete' state" control option affect the Thin Client, and if it does, how?
For example, we know that the "This is a 'Released' state" also affects the Thin Client as it, by default, only shows "Released" files.
I was wondering what other effects does this "Obsolete" flag have? Does it affect how children/parents are resolved?
If you have your Thin Client set to Released Only, it won't show the Obsolete states, which is currently affecting our own viewing access. Users who search a file in Thin Client are finding a previously released state without indication that the file was made Obsolete. You just get the cookie cutter "Not the Latest Version" flag. It's possible someone set up the state as "Released" to give Thin Client visibility.
As I looked into this further, the Obsolete and Released options aren't exclusive. You can have both Released and Obsolete settings applied. I have updated our settings to include our Obsolete files as Released file to fix our Thin Client issues.
