Hello NG,
i have a general question: I recently set up a new vault basic server. I then added different folders and also a folder for content center files. Now i made the mistake, to not define the content center folder as a library folder, i just made a normal folder for all library parts. Meantime i have about 100 desings with many content center parts (mostly screws) in the vault. Does the failure of not defining the content center folder as a library bring problems to me?
And if so, is there a way to migrate the content center folder to a library folder? i have now many designs with revision stages i need to keep so i cannot delete all of them and get them new into the vault with a new library folder.
Generally i would like to know whats the difference if there is a folder defined as library and if not..
Or is this not a problem for the designs?
Any hints would be very helpful!
Greetings
Alexander
