Difference between library and normal folder
Hello NG,
i have a general question: I recently set up a new vault basic server. I then added different folders and also a folder for content center files. Now i made the mistake, to not define the content center folder as a library folder, i just made a normal folder for all library parts. Meantime i have about 100 desings with many content center parts (mostly screws) in the vault. Does the failure of not defining the content center folder as a library bring problems to me?
And if so, is there a way to migrate the content center folder to a library folder? i have now many designs with revision stages i need to keep so i cannot delete all of them and get them new into the vault with a new library folder.
Generally i would like to know whats the difference if there is a folder defined as library and if not..
Or is this not a problem for the designs?
Any hints would be very helpful!
Greetings
Alexander
ryan
It's only a UI setting within the vault, functionally they behave the same.
Having your Content Center folder in vault showing as a regular folder won't cause you any trouble.
-Ryan
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
alain_miltenburg
Hi Ryan,
That is actually not true. There are indeed some functional differences between library and normal folders.
First of all, sub folders within a library folder cannot be moved. As a result, iFactories that were created or moved into a library folders cannot me moved anymore when any of its members exist in the member folder.
Another difference is the way Copy Design handles files within library folders. By default library sub components are reused and not even shown in the user interface.
Alain
