Deploy Vault Files (get) Automatically for Every User
dsouva
Message 1 of 13
dsouva
When I was at AU 2022, one of the speakers mentioned an add-on that would push files to the users workspace as specified by the Admin. I can't remember the name of the add-on or anything in google search results. This would be ideal for the design data folder. Any ideas?
Replies (12)
Message 2 of 13
jorgen.bjornes
I use a tool from NTI that does it quite nicely (NTI Vault deployment). It is a small client script in the user startup folder that silently and automaticalle gets what the admin specifies on windows logon. Makes administering design data, templates, vault settings, project file and addin configuration sooo much nicer.. Of course we hope to see it supported in vault proper soon...
Message 3 of 13
dsouva
Thanks. I'll see if we can try it out.
Message 4 of 13
dsouva
Do you have a link?
Message 5 of 13
swalton
Our Reseller offers a similar application for an annual per-user fee.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 6 of 13
tschaeferZNBXX
@dsouva
We have customized the DLLs to ensure when a user opens Inventor it automatically will get from Vault the template files.  This has allowed us to ensure users are getting the most up to date each day, I would need to look but it may be each time Inventor is open.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Message 7 of 13
ihayesjr
@dsouva
Was it Workspace Sync?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 8 of 13
dsouva
Workspace Sync requires the user to run the command. I'm looking for a more automatic way. One that will automatically sync a folder when the user starts Vault.
Message 9 of 13
ihayesjr
You can configure Workspace Sync to automatically run.
Vault 2023 Help | Synchronize Your Workspace from the Command Line | Autodesk
Irvin Hayes Jr
Autodesk, Inc.
Message 10 of 13
dsouva
This could work. Is there a way to specify synchronizing only specific folders? ie. $\Designs\CAD Support\Templates
Message 11 of 13
ihayesjr
-S
The full path to a valid synchronization settings file (optional). The synchronization settings file specifies the syncrhonization options. For more information on exporting a settings file, see Specify Workspace Sync Settings.
Vault 2023 Help | Specify Synchronization Settings | Autodesk
Irvin Hayes Jr
Autodesk, Inc.
Message 12 of 13
dsouva
I saw that but I assume it is referring to these settings (screenshot attached) but I don't see how to specify a specific folder to synchronize.
Message 13 of 13
ihayesjr
Sorry, I misunderstood your last question.
Workspace Sync will sync all folders. There isn't a way to select specific folders.
Irvin Hayes Jr
Autodesk, Inc.
