Custom Property File
davdelomb
davdelomb
I have a question about creating a custom property.
I want to create a property named: "MaxCode" (associations: File).
For the value of the property i want to get a part of the folder path where there drawing is located.
Like this:
Folder path: $/Drawings/_Demo/DMO/DMO-010 Test Property
File Property: MaxCode : DMO
I want to get the value in red out of the folder path and put it in the property "MaxCode"
the position of the value that i want is always in third position.
Is there a way to do this in vault?
Darin.Green
No. You would need to use C#, VB or similar and use the split string function.
string Folder_path: "$/Drawings/_Demo/DMO/DMO-010 Test Property"; // Variable to store the folder path
var get_third_occurrence = Folder_path.Split('/')[3]; // This will split the folder path by / and return the value to the right of the 3rd occurrence.
or Substring...
var str"$/Drawings/_Demo/DMO/DMO-010 Test Property";
var char_to_split_by = str.IndexOf("/");
var get_third_occurrence = index < 0 ? str : str.Substring(3, char_to_split_by );
both of these examples will return:
DMO
I'm quite sure Vault doesn't have this functionality built-in to split a string (path) into parts...
If this information was helpful, please consider using the Accept Solution
