Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Create PDF and Sync Lifecycle State And Revision As Source
7 REPLIES 7
Message 1 of 8
ThomasRambach
1046 Views, 7 Replies
In Vault 2021: When you use the Create PDF command and with Sync Lifecycle State And Revision As Source, checked. Do you have to have all the same properties available in the Design Representation category as in the Native file category or do only those available in the Design Representation category get synced? I'm trying to figure out why some drawings in the same category give the error "An error occurred while attempting to synchronize revisions between the source and the PDF file: Operation is restricted" when most other drawings in the same category do not.
Labels (1)
  • PDF
7 REPLIES 7
Message 2 of 8
gandhey
in reply to: ThomasRambach
Please note with PDF creation - the properties of the drawing file are not synced to the pdf. PDF file just syncs the State and Revision as that with the source drawing.
For the other error, please check your revision schemes configured in the category of the drawing files and the that in the Design representation category. You need to have the revision scheme used in the drawing file's category added in the Design representation category.
Following just for quick reference :
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Yogeshwar
(Vault team)
Message 3 of 8
ThomasRambach
in reply to: gandhey
@gandhey the revision schemes are the same, and as mentioned.. most files updated but 1 or 2 do not for some reason. Also, the properties are updating. When I publish an IDW or DWF ot PDF, the part number, description, and other properties are being updated on the PDF. What's the disconnect here?
Message 4 of 8
gandhey
I had to check with the dev-team for the property sync part, thus the delay in reply.
For the properties, the properties on drawing file, if mapped to 'Design Representation' category -> the property values from the drawing will be synced to PDF.
For the error you observe, just to confirm is the Lifecycle state synced properly for those 1 or 2 files. ?
Yogeshwar
(Vault team)
Message 5 of 8
ThomasRambach
Yes, most files sync perfectly. Some do not that are the same category, lifecycle defintion and state. The only difference may be the age of the file and what properties are applied. It's hard to diagnose without a specific error message. Would this be logged somewhere?
Message 6 of 8
gandhey
Unfortunately no, I suggest you to reach out to product support as this will need further investigation.
regards,
Yogeshwar
(Vault team)
Message 7 of 8
ThomasRambach
It sounds like the issue may be related to the native CAD file needing migration to the latest version.
Message 8 of 8
I discovered the issue was not the file migration but some old files where the Vault revision was "-" and not a numerical value like the revision scheme needed.
