could not find the Data Management Services on SERVERNAME - Windows update
YannickEnrico
Advisor Advisor
Message 1 of 12
YannickEnrico
So yesterday my computer decided to update itself.
That resulted in the above message this morning.
Been through these two topics:
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
http://blogs.autodesk.com/vault/2017/12/windows-10-updates-breaks-vault-server/
IIS is running, and I can confirm that by going to http://localhost
However, going to http://localhost/AutodeskDM/Services/InformationService.svc provides me with: (sorry for the translation from danish. Not sure the English one uses the same words) "The file or assembly "connectivity.content" or one of its dependencies could be loaded. Access refused"
How do I deal with that?
Can I repair my vault installation without needing a backup? (because my backup script has been broken for longer than I care to admit, I just found out)
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Replies (11)
Message 2 of 12
YannickEnrico
Also, I don't have a vault user on my computer. I do have an IIS_IUSRS though.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 3 of 12
johannes.bauer
Autodesk Support
Autodesk Support
Hi Yannick,
You can open the ADMS Console and trigger a manual backup before starting repair operation or re-install.
It is odd, that there is no AutodeskVault User in your machine, so please try to start ADMS Console and do a backup for saftey anyhow.
After that try to repair / reinstall from appwiz.cpl
HTH
-Johannes
Customer Technical Success
Message 4 of 12
YannickEnrico
I managed to fix it by doing a repair (before backing up, because I was out of ideas, and someone said somewhere on this forum that you -shouldn't- lose files by it.)
In regards to users, this is my user list. Sorry for the Danish 😛
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 5 of 12
YannickEnrico
I would, however, like an updated vault backup script. I'm no shark at coding and got handed this by my reseller.
It was for 2017, and I only updated the folder structure for ADMS 2018. However, it doesn't create a backup. Can you, or anyone, tell me what's wrong? Doesn't matter whether I run it as admin or not.
REM Backup script for  ****** comp. name ******* Vault
REM
Rem opret følgene mapper.
Rem C:\Vaultbackup
Rem ----------------------- Skal ændres herfra (Start)--------------------------
Rem sætter placering af backup
Set Backuppath=C:\Vaultbackup
Rem Placeing af ADMS (Connectivity.ADMSConsole.exe)
Set LocVaulMan="C:\Program Files\Autodesk\ADMS2018\ADMS 2018\ADMS Console\Connectivity.ADMSConsole.exe"
Rem Backup bruger. Lokal ADMS bruger.
Set Backupuser=administrator
Rem Backuppassword
Set Backuppwd=
Rem Vault databasenavn
Set Vaultdb=Vault
Rem ----------------------- Skal ændres hertil (****)--------------------------
rem ------------VVVVVVV--------skal ikke ændres ----VVVVVVVVVVVVVVV------------------
Rem slette gammel log fil
del /Q %Backuppath%\Logs\*.*
Rem Backuppath new
Set Backuppathnew=%Backuppath%\new
Rem Backuppath old
Set Backuppathold=%Backuppath%\old
Rem Placering af logfil
rem Set Logfil="%Backuppath%\Logs\Backup.txt"
Set Logfil="%Backuppath%\Logs\Backup %DATE%.txt"
Rem opretter logfil katalog
Rem MKDIR %Backuppath%\Logs
Rem slette backup old
RMDIR /Q /S %Backuppathold%
Rem omdøber backupfolder fra new til old
REN %Backuppathnew% old
Rem oprette folder backup new
MKDIR %Backuppathnew%
rem nu udføres backup
%LocVaulMan% -Obackup -B%Backuppathnew% -VU%Backupuser% -VP%Backuppwd% -L%Logfil% -DBSC
Rem Defragment af Vault
%LocVaulMan% -Odefragmentvault -N%Vaultdb% -VU%Backupuser% -VP%Backuppwd% -L%Logfil%
Rem slette backup BackupPaaServer
RMDIR /Q /S P:\Dropbox\Vaultbackup\
XCopy %Backuppathnew% /E/I/K/R/H/Y P:\Dropbox\Vaultbackup\
shutdown.exe /s /t 20000
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 6 of 12
johannes.bauer
Autodesk Support
Autodesk Support
I believe the server part is not correct:
 C:\Program Files\Autodesk\ADMS Professional 2018\ADMS Console\Connectivity.ADMSConsole.exe
Also make sure the ADMSConsole is closed in the task manager when trying to run the backup as it is only possible to open it once.
HTH
-Johannes
Message 7 of 12
YannickEnrico
I forgot to mention... This is all Vault Basic.
The filepath is correct
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 8 of 12
johannes.bauer
Autodesk Support
Autodesk Support
And the directory path is correct?
Did you check if ADMS Console is running when you execute the script?
Is there enough disk space free?
Have you checked ADMSCONSOLE.log on C:\ProgramData\Autodesk\VaultServer\FileStore for errors?
HTH
-Johannes
Message 9 of 12
YannickEnrico
For whatever reason it works now.
I did delete a ton off the harddrive, but there was 20 gb space to handle 6 gb vault when I tried earlier
I'm quite certain I didn't have ADMS console open.. But I might be wrong on that account.
If I run it as silent, will it just press yes to the dialogs about locking the vault?
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 10 of 12
YannickEnrico
Nope. I found the issue. Running it as silent makes it ignore those prompts and not create a backup.
How can I make it accept those dialogs (I.e. vault will be locked for defrag)? Because this script is set to run at 17.00, an hour after I usually leave my workplace
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 11 of 12
johannes.bauer
Autodesk Support
Autodesk Support
Hi Yannick,
-S
Run the utility in silent mode without any message boxes.
see here: https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/Help/EN...
HTH
-Johannes
Message 12 of 12
YannickEnrico
For whatever reason that runs now as well. I can't explain why it didn't  before.
Thank you very much for your help.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
