Copy Design
Copy Design
Message 1 of 8
Copy Design
Is it possible, without having Vault Admin. rights to change the list of columns shown in Copy Design?
Replies (7)
Message 2 of 8
ihayesjr
Yes, the columns shown in any dialog is based on the users preference it is not an admin setting.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 8
Thanks, but I'm not finding anything to do with Copy Design below. Am I in the correct place?
Manage User-Defined Properties
  1. Select Tools  Administration Vault Settings.
  2. In the Vault Settings dialog, click the Behaviors tab.
  3. In the Properties section, click Properties.
  4. You can:
    • Click New to create a user-defined property.
    • Select a property and then click Edit to modify a property definition.
    • Select a user-defined property and then click Delete to remove the user-defined property.
  5. Click the Settings tab to view the settings for the selected property. The settings displayed in the tab vary depending on the type of property selected.
Message 4 of 8
ihayesjr
Launch Copy Design. Right-click on any column header in the Copy Design dialog box and select Choose Columns.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 8
That was the first thing I did and why I went to the forum. My choices are sort or fit column.
Message 6 of 8
ihayesjr
What edition of Vault are you using and can you provide a screen shot of the Copy Design dialog?
Irvin Hayes Jr
Autodesk, Inc.
Message 7 of 8
See attached. I'm also only getting the Reuse or Copy file options.
Do I need to have Vault configured?
Thanks.
Message 8 of 8
ihayesjr
You are using the old version of Copy Design.  You cannot change the columns in that version.
Irvin Hayes Jr
Autodesk, Inc.
