Copy Design
johan.degreef
Copy Design
johan.degreef
Don't know what is happening, but copy design fails because of duplicate filenames. As in the error dialobox it states that there is a "23068_2005.dwg" and a "copy of 23068_2005.dwg"
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
jorgen.bjornes
Could it be that you have more than one component as base view? and copy design tries to copy drawing for each of them?
When this happens I enable drawing view, name the "extra drawings" with prefix "deleteme_", "deleteme2_" etc  and delete them after the copy design
johan.degreef
@jorgen.bjornes
It was exactly that. I just could not see the "extra drawings in my numbering panel for renaming, so i delete the extra view on the drawing in question. Then it worked...
Very unpleasant if you have it with multiple files...
jorgen.bjornes
yes, this one is a pain the the ¤&%..
It would be useful with some extra intelligence in the copy design logic, or even some more control, like being able to mark a drawing instance in the copy design dialog and mark it as "ignore" or something.
Glad you solved it! 🙂
