My issue is with the Copy Design feature in Vault.
The issue is specific to my workstation. The other workstations at my work do not have this issue. I have compared project file, vault and inventor settings with other workstations and haven't been able to find any discrepencies.
After I have right clicked on a file and selected Copy Design, the Copy Design window pops up.
In this window I have 2 different sources of error messages.
Under the "Vault Path" column, the path of the file I want to copy is highlighted in red. The path begins with a $ and is the correct path to the file. The other workstations display the same path, but no errors. When I click on this red highlighted path, I get the error message:
An error occurred while attempting to retrieve a folder.
The other error source is when I try to change the path of either the "Copy Design From:" or "Copy Design To:" fields. By default, these paths are different than the other workstations at my work. The differences being my path starts with "C:/$LocalWorkingFolder" instead of "$", and the end of my path does not include the specific part directory.
Example of the difference in default paths between my workstation and others:
My workstation: C:/$LocalWorkingFolder/Designs/Blueprints/
Others: $/Designs/Blueprints/01000/
When I try to add the specific part directory to the end of my path, (C:/$LocalWorkingFolder/Designs/Blueprints/01000/) I get the error message:
The path is invalid. Please re-enter a valid path.
When I try to modify the beginning of my path to match what the other workstations use ($/Designs/Blueprints/01000/) I get the error message:
You must specify a folder which starts with
In your vault client go to tools > options, at the bottom there's an option to pick your inventor IPJ file, select the right one and that can solve a lot of path related problems in copy design
Neil,
Thanks for the response.
With the correct project file selected I still have this problem. At my work we keep the IPJ file on vault so everyone works off of the same one. However the issue is still limited to my workstation.
Riley
