Copy design - Copy folder structure and and files within
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
I'm looking for a way to copy every single file within a folder structure, including the folder structure itself. In the overview example below this would mean copying to a folder called "Top folder for second unit".
All of these files will be given a new file name and part number during the process, xxxx-yyy-zzz will become xxxx-ppp-zzz and so on. This is the whole purpose of the copy since the same client has ordered two nearly identical units which requires separate documentation. In theory, the same client could order 20 nearly identical units so this process has to involve as few manual operations as possible.
We will use the same process for new clients when we copy template units.
One unit contains on average about 500 ipt's, 80 iam's and 110 idw's.
Folder structure overview:
Content of folders:
- Client drawing no. 1-10 folders (10 separate folders): IDW's made mostly using the top component (located in "Production folder")
- Subassembly no. 1-40 folders (40 separate folders): All ipt's, iam's and idw's (fabrication drawings) for that specific subassembly
Autodesk Vault Professional 2016
Thanks in advance.
