i have defined three rules in one rule set. This worked well for a long time.
But now the problem is:
If the condition of one rule is met, only this rule will be executed and no further rules are executed.
I can't say exactly when this problem started. We noticed it later. Maybe it was after an update?!
I have created a new rule set, but it didn`t help
Vault professional 2024 - Update 2024.3.1
Vault Server - Update 2024.3.1
Please help me
Greetings
Marc
Copy Design only ever executed the first rule that matched the criteria.
When we started with Vault 2024 last year, it definitely wasn't like that.
3 rules in a set:
One rule that always sets the part number equal to the file name.
And two more rules that set a custom property to empty if it wasn`t empty.
I have done many copy operations like this and all three rules were executed.
According to this support case, several users have already reported this:
I'm sure it was changed with an update, but unfortunately I can't say which one because we didn't notice the problem right away.
It has always worked that way. Yes, that article shows it was reported; the problem is that it was not updated to tell you it is working as designed.
I will get that article updated.
Sorry, the article does state it is working as designed.
See the Status section of the article.
