Check in dialog empty
rwollenhaupt
rwollenhaupt
I have an assembly I cannot check into the Vault. The Check-in process seems to be going normal until the Check-in dialog box comes up. The file I'm trying to check in is not listed and the OK button is grayed out. I get no error message. There is no unresolved link issue. I had lower level parts in this assembly that checked in when trying to check in this assembly, but the top level assembly will not display in the list  for check in. I have attached a screen shot of the dialog box. Check in dialog.JPGAny suggestions? Thanks in advanced.
Bob Wollenhaupt
tschaeferZNBXX
Can you show us the settings you are using?
I have seen this with LOD being active that is not the master.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
rwollenhaupt
Matt,
I don't think it's a settings issue because while in the file with the problem I can check in lower level parts. I will switch to the Master LOD and wee if that solves the problem. Thanks for the suggestion.
Bob Wollenhaupt
tschaeferZNBXX
We have noticed that the LOD is not always the answer but this is when I have seen this happen.
*AU Speaker 2018*
* AU Speaker 2017 *
rwollenhaupt
Matt,
Switching to the Master LOD solved the problem.
Bob Wollenhaupt
