Change Order numbering scheme
Tony_Yates
Tony_Yates
Hi Guys,
I have tried to create a change order numbering scheme
but when I create a new change order it just appears as --01, I don't get the free text or pre-defined list.
Is there a setting that needs to be activated?
Cheers,
CGBenner
@Tony_Yates
What version of Vault is this?  Do you have the numbering scheme selected as active?  Can you show us what you see when you create a new Item?
Chris Benner
ihayesjr
@Tony_Yates
Please create a support case. I was able to reproduce this.
It shouldn't show up this way.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Tony_Yates
I have opened up a support case for this issue.
Tony_Yates
Hi Chris,
Vault pro 2021.
result when creating a new change order is --01
I have opened a support case on this issue.
cheers
Tony
CGBenner
@Tony_Yates @ihayesjr
I could not reproduce this at first, but then I realized I was using the Item Numbering scheme, not Change Order.
Chris Benner
