Cannot login to vault 2022 after recent client update
f.vandijkE4VJX
Message 1 of 14
f.vandijkE4VJX
Hello, today I installed a new update for the vault client 2022. But after startup i see a "privacy settings"  screen. but the loading is stuck. I think i need to hit  "Ok" the the privacy settings dialog, but the "Log in" dialog is preventing that. however, i cannot close the Login dialog. (clicking X doesnt do anything, everything else is grayed out.)
same happens if i launch vault client 2020.
I tried rebooting, that didnt work. I tried shutting down the ethernet connection, that had some effect  But still could not close the login dialog. Any other suggestions?
Edit i found a work arround by starting inventor 2022 first, that one did let me allow to apply to terms and conditions..
Replies (13)
Message 2 of 14
chris.downing
thanks for the workaround
ACADE & PLANT3D Applications Engineer
CAD Training
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
Message 3 of 14
jweiss1313
I just downloaded and installed Vault Pro 2022.2 from Autodesk accounts and installed it and I have a user who cannot login due to the Privacy window.  You can't even select OK on the privacy window.  User is not a CAD user so I can have him use the work around mentioned in this post.
We just upgraded to Vault Pro 2022 last November and the version I downloaded thankfully did not have any privacy statement window that popped up.  Only some remote users that I installed Vault directly from Autodesk Accounts recently are having this issue.
Is there a fix to this bug???
Appreciate someone from Vault team to chime in to help.  I would appreciate it.  Thanks in advance.
@ihayesjr
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 4 of 14
ihayesjr
@jweiss1313
I am looking into a workaround for you. I will get back to you ASAP.
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
Message 5 of 14
ihayesjr
@jweiss1313
For your user can you have them launch DWG Trueview and close the Privacy dialog?
Irvin Hayes Jr
Message 6 of 14
jweiss1313
Hi Irvin,
I will contact the remote user and give it a try.  I will let you know how we make out.  Thank you so much for the quick response!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 7 of 14
jweiss1313
Hi Irvin,
That worked.  Thank you very much!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 8 of 14
steveh5
FYI...we are seeing same issue since we upgraded to VP2022. We are still using 2021 Thick Client and INV2021, as we slowly bring on 2022 Thick Client and eventually INV2022.
Solution is to start Inventor first and get logged into Vault.
Then log into Thick Client.
Once you get thru that Privacy Window, doesn't matter which you start first after that.
HTH,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 9 of 14
ihayesjr
All,
We are looking to address this issue in a future update.
Irvin Hayes Jr
Message 10 of 14
corym
Just had the same issue here this morning.
Workaround worked.
Cory McConnell
Message 11 of 14
steveh5
Ironically we did too on a couple of machines. Hadn't see this for a couple of weeks. I was blaming upgrade to 2022 Vault Server, but that was about 2 months ago.  Those machines use Inventor / Vault daily and why today? Hmmmm
Steve Hilvers
Message 12 of 14
ThomasRambach
This is impacting Vault 2021 without any updates being applied. It just randomly appeared.
Message 13 of 14
ihayesjr
The Privacy dialog is a shared component for all Autodesk products. Any product could have reset the privacy agreement prompting it to show again.
When it comes to Vault, the login dialog causes the user not to be able to accept the Privacy agreement. This should be addressed in a future Vault update.
Irvin Hayes Jr
Message 14 of 14
tomasz.sztejka
And up to then what? Should I suspend paying the subscription? Shut down the company? How can I work around it when I have no access to Inventor and DWG True View isn't asking about anything? Please be more considerate and provide some work around or stop sending requests to show privacy settings dialog to versions which do have this bug.
