Cannot change Item title
donalmcnamee
donalmcnamee
I have a couple of items in my Item Master for which I can't seem to change the Title.
The item is in Edit Mode, I can change the Description just fine, but not the title. The Title text-box seems to be grayed-out also.
This is just happening on a handful of items.
What could be going on?
  • item
ihayesjr
The Title is driven by the primary file attached to the Item.
Most likely your mapping for the Title property is one way, from File -> Item.
Check your property mapping for the Title property.
Keep in mind Vault will not be able to write back to a PDF.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
donalmcnamee
@ihayesjr
Well spotted!
The PDF was incorrectly associated as the Primary Link to the Item.
Changing it back to the IPT file corrected the issue.
Thanks for your help!
