Can't check in Navisworks file after checking out and editing file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have issues with Navisworks file with Vault.
I have a Navisworks file (NWD) checked in. I then have to create a new version from my Inventor model or edit something in the file. I then check out the Navis file and save the newly created version under the same document name/edit the file. After that, the Check In button in Navisworks turns grey and I can't check the file in anymore. The vault browser gives also no option the check in. Trying to check in directly from the Vault client gives an error that the file can only be checked in from the appropriate appliation. I can only check in when I click the Refresh button on the Vault tab, but that loads the last version from the Vault and checks that version in again. So my changes are not vaulted.
The only thing I always do when I check in a new Navis file (first time check in) is edit some user defined properties in the Vault client. It looks like after that I can't edit the file anymore.
Is this issue known or are we doing something wrong?
Using Inventor, Navisworks and Vault client 2019. Vault server recently updated to 2021, but this issue was also present with server 2019.
