BOM First Level report actually multi-level?
CadUser46
Message 1 of 14
CadUser46
I'm using the report from "C:\Program Files\Autodesk\Vault Professional 2016\Explorer\Report Templates\BOM - First-Level.rdlc" but it shows rows 1.1,  1.1.1 etc
Am I wrong in thinking it should only show the first level of the BOM?  Right now it seems identical to BOM - Multi-Level so I already compared a copy from another users machine in case I had accidentally overwritten it.
Inventor 2010 Certified Professional
Currently using 2023 Pro
Replies (13)
Message 2 of 14
johannes.bauer
Autodesk Support
Autodesk Support
Hi CadUser,
I can reproduce your view.
I will log a defect for this.
Still you can edit the reports yourself if needed.
You can find here an information for this.
Johannes
HTH
-Johannes
Customer Technical Success
Message 3 of 14
CadUser46
Hi Johannes
Thanks for agreeing with me.
Unless you're telling me otherwise I don't believe it's possible to edit the logic of reports as I have asked this question before.  Columns/layout/properties yes, actual logic no.  I have web developer 2008 but see no way to edit the embedded SQL to modify the multi-level into single level.
If you do know of a way to achieve this could you edit it and send me the report, or explain how to do it?
Craig
Message 4 of 14
johannes.bauer
Autodesk Support
Autodesk Support
Hi Craig,
Please select in the BOM View the First Level and re-execute the Report First Level.
Let me know if that helps.
HTH
-Johannes
Message 5 of 14
CadUser46
I had already tried that but did it again to be sure.  No change I'm afraid, it's still multi-level.
Message 6 of 14
johannes.bauer
Autodesk Support
Autodesk Support
Hi Craig,
Here is a screencast from 2018 version, where this is working correctly.
HTH
-Johannes
Message 7 of 14
CadUser46
I was using the BOM in the preview window so I copied your steps but still same result.  I'm using 2016 Vault Pro.
Message 8 of 14
johannes.bauer
Autodesk Support
Autodesk Support
Hi Craig,
thanks for verification.
Any plans to update to 2018? 🙂
HTH
-Johannes
Message 9 of 14
CadUser46
Not anytime soon.  Can you duplicate the error in 2016?  Is the bug in the report or Vault?
Message 10 of 14
johannes.bauer
Autodesk Support
Autodesk Support
seems to work as well for me.
HTH
-Johannes
Message 11 of 14
CadUser46
So how do you propose to move this forward?  Remote desktop?
Message 12 of 14
johannes.bauer
Autodesk Support
Autodesk Support
I will follow up in a case
HTH
-Johannes
Message 13 of 14
Johannes pointed out the obvious.  It's not the logic of the report that make it First or Multi-Level, it's the filter selection in the UI before running the report.  The report names are just misleading 🙂
Posted from my other account.
Message 14 of 14
jacopo_chiappetti
you can use the filter selection in the UI, as stated, or you could modify the "first level" report adding, in the "rows visibiliy", the expression : =instr(Fields!Row_Order.Value,".")>0
this hide rows with row order contains a "." so 1.1, 2.3 ...
or put the same expression in the filter section of the table
