Backup a Vault only with virtual server tools
Hi all,
I want to know if anyone has an advice about backup a vault only with virtual server's tools like Veeam backup.
We're torn between making a standard ADMS backup and perform increment VMWare backup.
And, does anyone know the position of Autodesk about it?
I know it's a grey zone but many other SQL base use this way of doing things.
Thank for your answers.
ihayesjr
Thank's for the answer.
So backing up with a virtual server tool isn't a good idea and it's much better to use a SQL tool to do it?
Cheers.
ihayesjr
The goal of the whitepaper is to give you the information needed to use any tool to perform a Backup or Restore.  It is recommended that the tool you decide to use, you perform tests to verify that it is backing up and restoring properly.
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
