b2bMigrate question
b2bMigrate question
b2bMigrate question
Just wondering if it is safe to run the SQL 2017 Management Console while a b2bMigrate job from the command line is going on. I just want to verify a SQL Maintenance Job is disabled for today only. Thx,
Kevin.Jaufmann-Ludwig
Autodesk Support
Autodesk Support
Hi @Anonymous ,
as long as you are only viewing and do not any changes on the AUTDOESKVAULT instance (what should not be done anyway) this should be fine.
Kevin Jaufmann-Ludwig
Technical Support Specialist
Link Name | Link Name | Link Name | Link Name
