Automatically catagorized and assigned to a life cycle
CAD-One
Message 1 of 18
CAD-One
Upon check in how can I automatically assign to both; a catagory and a life cycle.
I created a rule. Looks like it catagorized it. but dont assign to a life cycle.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
Replies (17)
Message 2 of 18
Dan_Margulius
Life cycle must be attached to the category.
When you check in files you can build a criteria that files with some ending(.dwg; .xls; .iam...) will go directly to
Message 3 of 18
CAD-One
Sounds like an answer. Will try tommorow. Thx
C1
AutoCAD 2020
Message 4 of 18
JamesMcMullen
I would also check that the category you are using has a default lifecycle assigned to it.  -Jim
James McMullen
Principal SQA Eng.
Message 5 of 18
CAD-One
Dan,
Why is my dialog box not same as yours?
I use VC 2012.
I see your first image shows 3 behavious tabs "Lifecycle" "Revision" and "Properties".
In VC2012 I dont have them. All I get is "Properties"
How can I assign automatic Lifecycle upon checkin of inventor files?
Thx
C1
C1
AutoCAD 2020
Message 6 of 18
CAD-One
Jim,
Is this possible in VC2012?
Like I mentioned, my dialogboxes are different from what Dan posted in his reply.
So I am thinking these are Vault Profressional Tools.
Right?
C1
AutoCAD 2020
Message 7 of 18
Dan_Margulius
Please post pictures with what you see from VC 2012
Dan
Message 8 of 18
CAD-One
Hi Dan,
Thanks for the response.
I am on road right now. But I clearly remember that my VC2012 configure category dialog has only "Properties" tab as posed to 3 tabs from your first image.
I can post it first thing on Monday.
C1
AutoCAD 2020
Message 9 of 18
CAD-One
Here is my Screen Shot for Configure Catagories.
Why dont I see tabs for Life Cycle & Revisions (Like it shows in the image from Dan's Post above?
Without these, Cant I make Catorization & automatic life cycle assignment?
C1
AutoCAD 2020
Message 10 of 18
CAD-One
Can somebody verify this for me. Does your dialog show tabs? Is there some kind of settings I need to turn on?
C1
AutoCAD 2020
Message 11 of 18
Dan_Margulius
Switch to File Categories and try.
Now you are on folders.
Dan
Message 12 of 18
CAD-One
Dan,
You are the man !!
Thanks for pointing this out. I was being hasty & It was so frustating.
I am pretty sure apart from just assigning to a catagory and lifecycle, there must be much more we can do on the properties tab.
Do you what other good stuff can be done upon checkin? Can you share?
Thx
C1
C1
AutoCAD 2020
Message 13 of 18
Dan_Margulius
Good to hear you manage it. Other good stuff I do :
Avoid vault where you can 🙂
Dan
Message 14 of 18
CAD-One
Dan, You wont believe it. None of my collegues like Vault. Invariably we have hot discussions aleast once every day.
Since, I showed a little interest, I am the administrator and get a lot of this heat. 😞
Anyways, thanks for the support.
C1
AutoCAD 2020
Message 15 of 18
Dan_Margulius
Jokes aside, vault is very powerful.
  • Show them the advanced Find tool where you can save searches as folders.
  • Show them the version management that Vault does alone.
  • How they can pull previous version and work on it.
  • Drawing compare between two versions...and more
Any way my opinion is that if you are the Vault Admin you have the power.
Use it wisely, drafters are easy to find and hire, smart people who can manage data are hard to find.
Dan
Message 16 of 18
JamesMcMullen
Dan/C1,
You can use the Autodesk Vault Idea Exchange to report things that will make your Vault experience better.
-Jim
James McMullen
Principal SQA Eng.
Message 17 of 18
Dan_Margulius
Jim,
Autodesk knows very well what needs to be done to make our expierence better.
Lets hope it wont take another 5 years.
Dan
Message 18 of 18
CAD-One
Jim,
Thanks for the link. Will try to make best use of it.
C1
AutoCAD 2020
