Autoloader not allowing me to map to target folder
When using Autoloader, and get to the point of browsing to the target folder, I get a "you do not have adequate permissions to perform this operation" message.
I am logged in as Administrator.
I am able to create a folder during the target mapping step.
It doesn't matter which folder I select, all result in the same message.
I have attempted this on two different pc's with the same result.
I am able to check both DWG and Inventor files into Vault via their respective applications.
Any idea what might be causing this Autoloader permissions error and how to correct it?
Autoloader was working several weeks back, but now I have this issue.
I am using Vault Professional 2014 release 2.
Although an administrator, you specifically have to grant this user account write-permissions to the folder (folder/document category/lifecycle user right assignments overrules the administrator-permissions).
Thank you for your reply.
Maybe I am mis-understanding your reply but I believe my admin account has write-permissions against this and other folders in Vault. See attached #2.
An additional note:  I am able to check-in files via the CAD application from the Vault tab.
I can also check multiple files in via the application Vault server option which will check in all files form a designated source folder. See attached #3.
I am also able to create a Vault folder at this step in the upload process.
Found that having a permissions group called "everyone" with read-only privileges was over-riding the admin privileges. Once I removed the "everyone" group I was able to map to the target folder during the Autoloader upload process.
