Autodesk Viewer only populates a hundred
bradley_weiss
Message 1 of 9
bradley_weiss
We have a lot of file in our Vault.  But in our Autodesk Viewer only populates a hundred. Is there a setting you can change this or something so you can see next files past 100?
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
Replies (8)
Message 2 of 9
TheCADnoob
It looks like you may be able to increase your search results. Check out this thread.
https://forums.autodesk.com/t5/vault-forum/search-should-display-just-100-items/td-p/9612304
CADnoob
Message 3 of 9
bradley_weiss
Thanks, this must be on the Server side. I have Admin rights. but don't have the Advanced Setting Tab option.
Thanks for the reply.
Message 4 of 9
dany_rochefort
@bradley_weiss
There is no limit. However in this case it's showing 100 folders cause of proabably have 100 folders. This has nothing to do with how ever many hundreds of files are contained within those folders.
Message 5 of 9
bradley_weiss
We have a 1000 Folders,  It only shows 100 Items at a time folder or files. I couldn't find anywhere  to change the limits. I  sent a e-mail to our IS to check if there was a setting on the Server side,
Message 6 of 9
dany_rochefort
@bradley_weiss  It might be a sever side setting as you say... I've checked on my end with Admin rights as well and could not see anything in that regard.
Message 7 of 9
CGBenner
@bradley_weiss
When you say Autodesk Viewer, what exactly are you looking at?  What version and type of Vault? (eg. Vault Basic 2020).  Is this thin client or full Vault Client?
Chris Benner
Message 8 of 9
Frederick_Law
Usually it looks like this when I search in Vault:
Message 9 of 9
bradley_weiss
It is a Thin Client Viewer. I found out it is on the server side. and it can only be set to 1000. Thanks for Responding.
