- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have a problem to establish a SSL connection on a customers system.
Everthing works well with http.
The server has a valid Cert (FQDN and hostname), all configs and xmls changed to FQDN as usual.
When I tried the first connect via https the client and also the server log told me, that the client and the server don't use a common protocol, IIS default website worked well.
Turned out that if you use a DOTNET 4 to 4.5 application on a system (here the server) which has installed a higher version of DOTNET than 4.5, you have to enable strong encryprion in the registry for DOTNET 4.
After setting these keys I was able to connect with the Vault Explorer and also with the Vault Web Client, but not with Inventor, AutoCAD or MS Office. These applications told me, that they can't find the Data Management services on the host. Do the client addins use other protocols and ciphers than the Vault Explorer, or do they not support strong encryption at all?
Versions:
Autodesk Vault Professional 2018.3
Autodesk Inventor 2018.3.1
Autodesk AutoCAD 2018.1.2
Autodesk AutoCAD Mechanical 2018.0.1
Microsoft Windows Server 2016
Microsoft Windows 10 Enterprise 1803
Anyone any idea?
Best Regards
Christian Schmidt
