- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Afternoon,
I'm trying to set up an Autodesk Vault Professionnal 2013 server (for third party development purpose) and I didn't succede to resolve the "Failed to acquire a license" issue.
I did set up the FLEXnet service, and when I check server status via "Perform Status Enquiry" I get the following message :
Status -------- Flexible License Manager status on Wed 3/27/2013 14:56 [Detecting lmgrd processes...] License server status: [email protected] License file(s) on 10.180.105.43: C:\Program Files\Autodesk Network License Manager\License\VLTM2013enlicense.lic: 10.180.105.43: license server UP (MASTER) v11.10 Vendor daemon status (on 10.180.105.43): adskflex: UP v11.10 Feature usage info: Users of 85987VLTM_2013_0P: (Total of 5 licenses issued; Total of 0 licenses in use)
Witch seems to be all ok.
I turned off both server and client Firewalls (so it's not a blocked port issue).
According to this page : http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
I have also disabled IPv6 (its a Windows XP x64 Workstation) and rebooted it.
I also changed the hostname for the IP adress in the %Program Files%\Autodesk\ADMS Professional 2013\LICPATH.LIC file, and as it wasn't still working, I changed it also in the %Program Files%\Autodesk Network License Manager\License\VLTM2013enlicense.lic license file.
The only thing I might have done that isn't usual, is that the Autodesk Network License Manager is installed on the C: drive, when the Vault is installed on the E: drive. But as it seems to communicate through services, I don't think that configuration have any impact, do it ?
Do someone have an idea to resolve my issue ?
Also, do someone have a list of services that have to be started for the vault to be up and running ? I noticed that "FLEXnet Licensing Service" was always stopped, and when I start it and then fail to connect to the vault, the service is again stopped, is it normal ?
Thanks in advance for any help,
NC
