Autodesk Vault - noncompliant policies for DWF
Lukasz.Dudkowski
Lukasz.Dudkowski
I have the issue with "Noncompliant policies" on DWF file.
I have "1. site" parameter with is demanded by the system casing that issue.
Is there any possibility to copy "1.Site" parameter from native file automatically or I need to create special category with not demand this parameter ?
BR,
Łukasz Dudkowski
smilinger
You should only assign and demand this property on required categories instead of the property itself, this way you don't need to create a special category for DWF files.
Lukasz.Dudkowski
Right now property is defined on category level. I will remove it from demanded if no another idea will be posted. Still hope 🙂
Is there any way to copy property to DWF from source file ?
