ADMS Console 2026.2 slow to open
joe.corson
joe.corson
in the screen shots below you can see on 1/15 there was 10 seconds between the last 'GetLibraryInfo' and 'all vaults and libraries have already been migrated'.  On 1/16 i updated the console to Vault Pro 2026.2 and now there is a gap of ~8 minutes where the ADMS console just sits there trying to open. This is about the same amount of time for the AVFS consoles also, i had to modify the AVFS sendTimeout to 10 minutes just to open the AVFS consoles.
Why is there an 8 minute gap since the 2026.2 update?
Vault Professional 2026.2
Build 31.2.115.0
johannes.bauer
Autodesk Support
Autodesk Support
Currently, this can happen if your Vault is quite large due to on-site file calculations.
If this is the same root cause we are already working on fixing it. Otherwise, feel free to open a support case to analyse it in more detail.
HTH
-Johannes
Customer Technical Success
johannes.bauer
Autodesk Support
Autodesk Support
joe.corson
I guess we would fall under the 'quite large' category. I will wait for a fix. Thank you for the response.
