what SelectEntitySettings.GridConfig change to in Vault 2016
wesbird
wesbird
I'm working on migration my AddIn from 2014 to 2016. here is one item I have difficult:
I search in google, autodesk forums, blogs but found nothing.
I tried
settings.OptionsExtensibility.GetGridConfiguration = config;
it does not works.
What should I change my code?
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
wayne.brill
Hi Wes,
Maybe you could use the approach in the Vault Browser SDK sample:
C:\Program Files (x86)\Autodesk\Autodesk Vault 2016 SDK\vs12\CSharp\VaultBrowserSample
It uses Vault.Forms.Controls.VaultBrowserControl.Configuration and then calls the SetDataSource() of the VaultBrowserControl passing in that configuration.
If this does not help attach a small project I can use to research the problem. (let me know if you want to keep it confidential)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
wesbird
Thank you, Wayne.
I check the code in C:\Program Files (x86)\Autodesk\Autodesk Vault 2016 SDK\vs12\CSharp\VaultBrowserSample.
In my case I use:
var results = VDF.Vault.Forms.Library.SelectEntity(conn, settings);
I cannot find place to set configuration. Any idea?
Wes
wayne.brill
Hi Wes,
Here is a reply I found with a suggestion to try:
Fill in the SelectEntitySettings.OptionsExtensibility.GetGridConfiguration.
• Below I’ve code similar to the default that happens if you don’t fill this in, but I’ve modified it to remove the “Author” property and the “Approved by” property.  If you have a particular property you want to remove, then debug the below code and look at the propDefs variable to figure out the key name of the property you want to remove.
• I’ve also modified it to get properties which are only active (I think this is what you want).  See the last parameter of the call to GetPropertyDefinitions below:
            Vault.Currency.Properties.PropertyDefinitionDictionary propDefs = connection.PropertyManager.GetPropertyDefinitions(null, null, Vault.Currency.Properties.PropertyDefinitionFilter.OnlyActive);
            // Remove "Approved By" and "Author"
            propDefs.Remove("1301cf04-4252-4d4a-8982-12e082d54211");
            propDefs.Remove(Vault.Currency.Properties.PropertyDefinitionIds.Server.Author);
            Vault.Forms.Controls.VaultBrowserControl.Configuration initialConfig = new Vault.Forms.Controls.VaultBrowserControl.Configuration(connection, "SelectEntityDlg." + settings.PersistenceKey, propDefs);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.EntityIcon);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.VaultStatus);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.EntityName);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.VaultStatusModifier);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.CheckInDate);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.Comment);
            initialConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.ThumbnailSystem);
            initialConfig.AddInitialSortCriteria(Vault.Currency.Properties.PropertyDefinitionIds.Server.EntityName, true);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.EntityIcon);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.VaultStatus);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.EntityName);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Client.VaultStatusModifier);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.CheckInDate);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.Comment);
            initialConfig.AddInitialQuickListColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.ThumbnailSystem);
            settings.OptionsExtensibility.GetGridConfiguration = e => initialConfig;
If this does not help please provide a project I can use to research this issue.
Wayne
Wayne Brill
