Data Standard hiding Numbering Scheme field
FedotovAnton
FedotovAnton
is it possible to hide or disable Numbering Scheme for drawings? For example - if file name has IDW extension - hide Numbering Scheme field?
Anton
wangdu
You need to return $null from the GetNumSchms function defined in the Default.ps1 file. Your numbering scheme combobox will be diabled and the FileName textbox will be visible.
Check this old post on how to check the file type in the GetNumSchms function
http://forums.autodesk.com/t5/vault-customization/2015-r2-datastandard-filename/m-p/5376391#M2703
Hope it helps!
Wangdu
FedotovAnton
Works like a charm 🙂
Thanks!
