Vault API - How to rename a file
Message 1 of 10
I am trying to rename a file accordance to a pattern, but it seems I have trouble doing it - do I need to checkout and checkin file after the change? If yes can you provide a code sample (C#) how to checkout file, rename it, checkin using Vault API? Thank you.
Replies (9)
Message 2 of 10
minkd
The CheckInUploadedFile method has a newFilename parameter.
You rename a file by checking it out and checking it in with a new name.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
Message 3 of 10
Thanks. When I use conn.WebServiceManager.DocumentService.CheckoutFile there is no checked out  file at the location I specified (C:\tmp").  What I am doing wrong?
Message 4 of 10
CheckinUploadedFile asks me for uploaded file, but I don't know how to do it. If you can provide a code example for checkout, checkin it would be great.
Message 5 of 10
minkd
Please see this blog post:  http://justonesandzeros.typepad.com/blog/2013/05/how-to-acquire-files.html
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
Message 6 of 10
darius.simkunas
File checkedOutNewFile = CheckOut(folders[0], selectedFile);
if (checkedOutNewFile != null)
CheckIn(folders[0], checkedOutNewFile, newname, Coment);
public File CheckOut(Folder folder, File file)
string localPath = _connection.WorkingFoldersManager.GetWorkingFolder(folder.FullName).FullPath;
if (!System.IO.Directory.Exists(localPath))
System.IO.Directory.CreateDirectory(localPath);
AcquireFilesSettings settings = new VDF.Vault.Settings.AcquireFilesSettings(_connection);
settings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = Autodesk.DataManagement.Client.Framework.Vault.Currency.VersionGatheringOption.Latest;
settings.OptionsResolution.OverwriteOption = AcquireFilesSettings.AcquireFileResolutionOptions.OverwriteOptions.ForceOverwriteAll;
settings.LocalPath = new VDF.Currency.FolderPathAbsolute(localPath);
settings.AddFileToAcquire(
new VDF.Vault.Currency.Entities.FileIteration(_connection, file),
VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download | VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout);
VDF.Vault.Results.AcquireFilesResults result = _connection.FileManager.AcquireFiles(settings);
foreach (var r in result.FileResults)
return m_serviceManager.DocumentService.GetFileById(r.File.EntityIterationId);
public File CheckIn(Folder folder, File file, string newname,string comm)
string filePath = System.IO.Path.Combine(localPath, file.Name);
VDF.Vault.Currency.Entities.FileIteration ff = _connection.FileManager.CheckinFile(
new VDF.Vault.Currency.Entities.FileIteration(_connection, file), comm, false, null, null,
true, newname, file.FileClass, false,
new VDF.Currency.FilePathAbsolute(filePath));
return m_serviceManager.DocumentService.GetFileById(ff.EntityIterationId);
Message 7 of 10
Thank you, Dave.
Message 8 of 10
Thank you!
Message 9 of 10
I have renamed file successfully as per your code. But, now, the links are broken. What I have missed. How I can keep links while renaming the file?
Message 10 of 10
darius.simkunas
VDF.Vault.Results.AcquireFilesResults result = null;
File checkedOutNewFile = CheckOut(folders[0], selectedFile, ref result);
               CheckIn(folders[0], checkedOutNewFile, newname, Coment, result);
public File CheckOut(Folder folder, File file, ref VDF.Vault.Results.AcquireFilesResults result)
           if (folder == null)
               folder = _connection.WebServiceManager.DocumentService.GetFolderById(file.FolderId);
           return null;
       public File CheckIn(Folder folder, File file, string newname, string comm, VDF.Vault.Results.AcquireFilesResults result)
           if (folder == null)
           FileAssocParam[] assparamsarr = null;
           if (result != null)
               FileRelationshipGatheringSettings settings = new FileRelationshipGatheringSettings();
               settings.IncludeChildren = true;
               var fassoc = _connection.FileManager.GetFileAssociationLites(new long[] { result.FileResults.First().NewFileIteration.EntityIterationId }, settings);
               List<FileAssocParam> assparams = new List<FileAssocParam>();
               foreach (var **** in fassoc)
                   FileAssocParam param = new FileAssocParam();
                   param.CldFileId = ****.CldFileId;
                   param.RefId = ****.RefId;
                   param.Source = ****.Source;
                   param.Typ = ****.Typ;
                   param.ExpectedVaultPath = ****.ExpectedVaultPath;
                   assparams.Add(param);
               assparamsarr = assparams.ToArray();
              comm,
              false,
              assparamsarr,
              null,
              true,
              newname,
              file.FileClass,
              false,
