Vault API - how to search for particular file
I want to check if the file name already exists in Vault. I create a new string with new file name. Tried to use FindFilesBySearchConditions() with the following settings:
            Autodesk.Connectivity.WebServices.SrchCond searchCondition = new Autodesk.Connectivity.WebServices.SrchCond();
            searchCondition.PropDefId = 95;
            searchCondition.PropTyp = PropertySearchType.SingleProperty;
            searchCondition.SrchOper = 3;
            searchCondition.SrchTxt = "544-0002-Nebojsa_2.xlsx";
but I am getting no hits although there is one file with this name. I have read a few posts here and online about using FindFilesBySearchConditions() but still need clarification. What exactlt I need to do in setup to successfully use FindFilesBySearchConditions() in my file search? If you can provide a code example it would be appreciated. Thank you.
Patrick.Gruber
Hi nebojsa.karadzic,
I have just made a quick example for you, it is written in powerShell and I have used powerVault (which is completly free!!):
Open-VaultConnection
function Get-FilesInVaultByName($fileName) {
    $propDef = $vault.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE") | where { $_.DispName -eq "Name"}
    $searchCondition = new-Object Autodesk.Connectivity.WebServices.SrchCond
    $searchCondition.PropDefId = $propDef.Id
    $searchCondition.PropTyp = [Autodesk.Connectivity.WebServices.PropertySearchType]::SingleProperty
    $searchCondition.SrchOper = 3
    $searchCondition.SrchTxt = $fileName
    $rootFolder = $vault.DocumentService.GetFolderRoot()
    $searchStatus = new-object Autodesk.Connectivity.WebServices.SrchStatus
    $files = $vault.DocumentService.FindFilesBySearchConditions(@($searchCondition), @(), @($rootFolder.Id), $true, $true, [ref]$null, [ref]$searchStatus)
    return $files
Get-FilesInVaultByName "Pad Lock.iam"
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos!
The author,
Patrick
coolOrange
www.coolOrange.com
arvindDWSMZ
Hello Patrick,
Your post was very useful. I find that the FindFilesBySearchConditions function returns only system details of the files- things like date created, size, file name etc and not any custom properties for the file(s). If i have custom properties setup for every file(for eg. Collection Label or a Description field), how can i get those values from the FindFilesBySearchConditions function ? or any other way ?
Arvind
Markus.Koechl
I just answered in another thread the same question: you need one more call to get all properties for the files in your result set. https://forums.autodesk.com/t5/forums/replypage/board-id/301/message-id/6703
In short: you need to search for files by search conditions and retrieve the properties based on this in a second step (for all files in the result in one single).
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
