I am writing a BOM reporter to count the quantity of each item in a multi-level BOM. Once the set quantity was entered into the top-level item's attribute value, it was multiplied by each assembly and part quantity to create the quantity. However, the quantities are being created incorrectly in the subparts of some assemblies. We want to create a successful multi-level BOM, so we're asking for your help. Please refer to the picture below.
Solved by smilinger. Go to Solution.
You can use custom code to calculate the result you want. Try this:
